New acquisition
Ron,
I wasn't sure about the dial scale, it's way too dirty to read at this point, but I did notice the shadow meter location which kinda led me to believe it is upside down. It's almost like the hinge design was backwards. If it was on the other way everything would be correct. However, the cabinet is notched out to accept the hinge, so it really can't be reversed. Almost makes you think someone goofed big that's why they stopped producing them, maybe?? also noticed on a second look at the chassis it has an outlet too, I'm guessing for a lamp, and someone in the past cut the speaker wires Icon_sad . nothing that can't be repaired.
There was a post awhile back on cleaning these dial scales. I don't remember what the consensus was to get it clean without removing the markings. Could someone please refresh my memory, it isn't what it used to be. Icon_smile
Glenn
Happily back in Illinois..not.
New acquisition - by Glenn Roberts - 08-04-2011, 10:47 AM
Re: New acquisition - by Ron Ramirez - 08-04-2011, 10:49 AM
Re: New acquisition - by Glenn Roberts - 08-04-2011, 11:55 AM
Re: New acquisition - by Ron Ramirez - 08-04-2011, 12:21 PM
Re: New acquisition - by Michael Dennis - 08-04-2011, 12:30 PM
Re: New acquisition - by Ron Ramirez - 08-04-2011, 12:36 PM
Re: New acquisition - by Michael Dennis - 08-04-2011, 01:58 PM
Re: New acquisition - by Glenn Roberts - 08-04-2011, 02:04 PM
Re: New acquisition - by Ron Ramirez - 08-04-2011, 02:27 PM
Re: New acquisition - by Glenn Roberts - 08-04-2011, 03:08 PM
Re: New acquisition - by Ron Ramirez - 08-04-2011, 03:36 PM
Re: New acquisition - by Sean - 08-04-2011, 04:27 PM
Re: New acquisition - by TA Forbes - 08-04-2011, 06:07 PM
Re: New acquisition - by Uffda - 08-04-2011, 06:16 PM
Re: New acquisition - by Chicago Jimmy - 08-04-2011, 06:44 PM
Re: New acquisition - by 7estatdef - 08-07-2011, 03:35 PM
Re: New acquisition - by Ron Ramirez - 08-08-2011, 07:33 AM
There are currently 10536 online users. [Complete List]
» 2 Member(s) | 10534 Guest(s)
