Philco 643 restoration
Thanks for the great tips!
This seller put chunks of foam in a box, placed the speaker cone down against it and piled on more foam. Of course, the foam chunks tore right through the cone.
Ah, I hadn't realized that was a date code on the output transformer. So it seems both the original and the replacement failed. I sure hope the one on the speaker doesn't burn out too!
Philco 643 restoration - by Bob Andersen - 08-04-2011, 10:13 PM
Re: Philco 643 restoration - by Bob Andersen - 08-05-2011, 01:44 AM
Re: Philco 643 restoration - by Ron Ramirez - 08-05-2011, 06:38 AM
Re: Philco 643 restoration - by TA Forbes - 08-05-2011, 12:36 PM
Re: Philco 643 restoration - by Ron Ramirez - 08-05-2011, 12:59 PM
Re: Philco 643 restoration - by Bob Andersen - 08-05-2011, 07:28 PM
Re: Philco 643 restoration - by TA Forbes - 08-05-2011, 10:07 PM
Re: Philco 643 restoration - by Bob Andersen - 09-02-2011, 04:29 PM
Re: Philco 643 restoration - by TA Forbes - 09-02-2011, 11:39 PM
Re: Philco 643 restoration - by Ron Ramirez - 09-02-2011, 11:43 PM
Re: Philco 643 restoration - by Bob Andersen - 09-03-2011, 12:30 AM
Re: Philco 643 restoration - by Ron Ramirez - 09-03-2011, 07:59 AM
Re: Philco 643 restoration - by 7estatdef - 09-03-2011, 11:44 AM
Re: Philco 643 restoration - by Arran - 09-05-2011, 01:24 AM
Re: Philco 643 restoration - by Bob Andersen - 09-07-2011, 11:11 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
