philco radio modernizing customization project DONE!
i actually have another radio i want to restore .....the case or cabinet is absolutly beautiful........not sure if radio works...was told it does but you know how that goes......
but is missing the face plate and knobs................i will post a pick maybe u can help id the model.....and where to get a face plate ,screws, and knobs....
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
There are currently 10431 online users. [Complete List]
» 2 Member(s) | 10429 Guest(s)
