Just came across a 49-1615
Hi Dan and welcome to the Phourm!
That's a tough question. I did take a look at that model and it seem to be one of Philco nicer sets. I think most here like doing the restoration work as a hobby. What it worth? Well you could find something like it on CL for $20-$100. Restored $100+ but the question is is anybody buying? I think if you go into it looking to make some money I doubt it will happen. If you like doing the work and don't mind putting $50 worth of parts in it then it's a match made in heaven. A lot of us just like to enjoy a good working set. But were an odd bunch!
ps Here's service info
http://www.nostalgiaair.org/Resources/656/M0013656.htm
Just came across a 49-1615 - by -Dan- - 08-05-2011, 12:00 AM
Re: Just came across a 49-1615 - by 7estatdef - 08-05-2011, 11:05 PM
Re: Just came across a 49-1615 - by -Dan- - 08-08-2011, 08:43 PM
Re: Just came across a 49-1615 - by 7estatdef - 08-10-2011, 06:48 PM
There are currently 7380 online users. [Complete List]
» 1 Member(s) | 7379 Guest(s)
