Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit".
3. From drop-down choose "Full edit".
4. In the "Subject" you will see the existing thread name: type your new name for the thread in it.
5. Press "Save".
This is it.
Eico 368 TV/FM Sweep Generator - by 462ron - 01-12-2024, 10:28 AM
RE: Heathkit Sweep Generator TS-4 - by RodB - 01-12-2024, 10:57 AM
462ron - by 462ron - 01-12-2024, 12:14 PM
RE: Heathkit Sweep Generator TS-4 - by RodB - 01-12-2024, 06:09 PM
462ron - by 462ron - 01-13-2024, 09:19 AM
462ron - by 462ron - 01-30-2024, 09:46 AM
462ron - by 462ron - 02-09-2024, 09:31 AM
RE: Heathkit Sweep Generator TS-4 - by radiorich - 02-09-2024, 10:14 AM
RE: Heathkit Sweep Generator TS-4 - by RodB - 02-09-2024, 10:52 AM
462ron - by 462ron - 02-10-2024, 08:44 AM
RE: Heathkit Sweep Generator TS-4 - by radiorich - 02-17-2024, 11:24 AM
462ron - by 462ron - 02-17-2024, 11:55 AM
462ron - by 462ron - 03-14-2024, 10:37 AM
462ron - by 462ron - 02-07-2025, 12:49 PM
RE: Heathkit Sweep Generator TS-4 - by morzh - 02-07-2025, 02:00 PM
462ron - by 462ron - 02-07-2025, 04:02 PM
RE: Eico 368 TV/FM Sweep Generator - by morzh - 02-07-2025, 04:29 PM
462ron - by 462ron - 02-08-2025, 09:00 AM
RE: Eico 368 TV/FM Sweep Generator - by morzh - 02-08-2025, 01:40 PM
There are currently 9388 online users. [Complete List]
» 1 Member(s) | 9387 Guest(s)
