1950 Emerson TV resurrection attempt
Today I got some final (I hope) work done. I know there are some that absolutley blast me because ... "WHY don't you just recap everything and it will work fine" folks. Uhmmmm... follow me and you will see just WHY. So, today I 'finished' the power supply, neated it up, added a CL90 (probably too big). I moved the heater wire to the other side of the CL so it would be softened on start up.
Next, I finished the recap on the audio section. Replaced the coupler, decoupling cap and another. Done.
I powered up to check things and this was the result:
I discovered a hum bar going up the screen and after some checks (think) found it was coming from the inrush current limiter, so I bypassed. Set works great for about 5 minutes then the HV drops off and pic goes to crap. So, next step - replace the cap inside the HV box that I suspect. That means pulling the big tube. It's ok, I want to clean things and test the tubes.
Before:
Tharez that lousy cap that is probably killing my HV.
Tim
1950 Emerson TV resurrection attempt - by TV MAN - 03-26-2023, 09:47 PM
RE: 1950 Emerson TV resurrection attempt - by TV MAN - 02-09-2025, 01:11 AM
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 4758 online users. [Complete List]
» 1 Member(s) | 4757 Guest(s)
