Model 20 Consolette Resto
Sorry but this just came to me.. Is it possible to add an auxiliary input to this set? If so where exactly do I hook it up? I am building my own AM transmitter but a direct connection would be nice too. Done tastefully of course. Low profile. I can start up several hours of old radio shows on an mp3 player and stash it inside the console and let people ask "what station is that?"..
Model 20 Consolette Resto - by badwaxcaps - 07-27-2011, 08:25 PM
Re: Model 20 Consolette Resto - by 7estatdef - 07-27-2011, 10:13 PM
Re: Model 20 Consolette Resto - by Jayce - 07-27-2011, 10:42 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 07-28-2011, 12:11 AM
Re: Model 20 Consolette Resto - by 7estatdef - 07-28-2011, 05:49 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-05-2011, 11:00 AM
Re: Model 20 Consolette Resto - by TA Forbes - 08-05-2011, 12:30 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-05-2011, 07:49 PM
Re: Model 20 Consolette Resto - by TA Forbes - 08-05-2011, 09:57 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-05-2011, 10:51 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-06-2011, 12:50 AM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-06-2011, 01:03 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-06-2011, 07:08 AM
Re: Model 20 Consolette Resto - by Dan - 08-07-2011, 08:24 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-07-2011, 08:43 AM
Re: Model 20 Consolette Resto - by Ron Ramirez - 08-07-2011, 08:46 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-07-2011, 09:19 AM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-12-2011, 11:25 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-13-2011, 09:12 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-22-2011, 12:03 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-22-2011, 08:49 AM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-24-2011, 12:31 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-24-2011, 04:35 PM
Re: Model 20 Consolette Resto - by Chicago Jimmy - 08-24-2011, 06:06 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-24-2011, 07:09 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-24-2011, 09:36 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-24-2011, 11:53 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-25-2011, 11:19 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 12:39 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-26-2011, 04:11 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 06:44 PM
Re: Model 20 Consolette Resto - by Ron Ramirez - 08-26-2011, 07:08 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 07:16 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 07:18 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-26-2011, 07:26 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 11:11 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 11:13 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-27-2011, 12:37 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-28-2011, 09:56 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-29-2011, 01:33 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-30-2011, 07:54 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-30-2011, 05:08 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-30-2011, 07:57 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-31-2011, 02:30 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-31-2011, 05:19 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-31-2011, 07:48 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-31-2011, 09:19 PM
Users browsing this thread: 15 Guest(s)
There are currently 10657 online users. [Complete List]
» 2 Member(s) | 10655 Guest(s)
