Cap Subs
They are wired in parallel externally. I have put a single .33 uF 200V cap in the bakelite block. Works as designed.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Cap Subs - by n9vu - 07-05-2006, 09:15 PM
Cap Subs - by planigan - 07-05-2006, 10:11 PM
Re: Cap Subs - by n9vu - 07-05-2006, 10:56 PM
[No subject] - by rghines1 - 07-06-2006, 12:19 AM
Cap Subs - by planigan - 07-06-2006, 12:52 AM
Re: Cap Subs - by n9vu - 07-06-2006, 05:43 AM
[No subject] - by rghines1 - 07-06-2006, 10:31 AM
[No subject] - by n9vu - 07-07-2006, 08:52 AM
[No subject] - by Terry Judkins - 07-07-2006, 03:45 PM
Cap Subs - by planigan - 07-09-2006, 03:55 AM
Re: Cap Subs - by n9vu - 07-10-2006, 08:37 PM
Cap Subs - by planigan - 07-10-2006, 10:15 PM
Cap subs - by planigan - 07-12-2006, 02:28 AM
Re: Cap subs - by n9vu - 07-12-2006, 06:35 PM
Cap subs - by planigan - 07-12-2006, 09:52 PM
Re: Cap subs - by n9vu - 07-14-2006, 05:55 AM
Cap Subs - by planigan - 07-21-2006, 02:29 PM
There are currently 8427 online users. [Complete List]
» 2 Member(s) | 8425 Guest(s)
