Cap Subs
Gary, you could use three .05s but you most likely would have to use a shoe horn to get them in the block. My last suggestion, e-mail me at planigan@suffolk.lib.ny.us with your postal address and I'll send you two .15's that I have and can't remember why I got them. One is an X2 safety cap ther other is ceramic. On the 37-650 I'm restoring two safety caps fit in the block so you should have no problem. Pat
Cap Subs - by n9vu - 07-05-2006, 09:15 PM
Cap Subs - by planigan - 07-05-2006, 10:11 PM
Re: Cap Subs - by n9vu - 07-05-2006, 10:56 PM
[No subject] - by rghines1 - 07-06-2006, 12:19 AM
Cap Subs - by planigan - 07-06-2006, 12:52 AM
Re: Cap Subs - by n9vu - 07-06-2006, 05:43 AM
[No subject] - by rghines1 - 07-06-2006, 10:31 AM
[No subject] - by n9vu - 07-07-2006, 08:52 AM
[No subject] - by Terry Judkins - 07-07-2006, 03:45 PM
Cap Subs - by planigan - 07-09-2006, 03:55 AM
Re: Cap Subs - by n9vu - 07-10-2006, 08:37 PM
Cap Subs - by planigan - 07-10-2006, 10:15 PM
Cap subs - by planigan - 07-12-2006, 02:28 AM
Re: Cap subs - by n9vu - 07-12-2006, 06:35 PM
Cap subs - by planigan - 07-12-2006, 09:52 PM
Re: Cap subs - by n9vu - 07-14-2006, 05:55 AM
Cap Subs - by planigan - 07-21-2006, 02:29 PM
There are currently 8574 online users. [Complete List]
» 1 Member(s) | 8573 Guest(s)
