What is this??? need an id....
It isn't a Philco, so moved this topic to the appropriate section.
Sorry, I don't know what it is either...but I know what it isn't... Icon_wink
What is this??? need an id.... - by Guest - 08-08-2011, 09:07 PM
Re: What is this??? need an id.... - by Ron Ramirez - 08-08-2011, 09:11 PM
Re: What is this??? need an id.... - by Jayce - 08-09-2011, 12:09 PM
Re: What is this??? need an id.... - by 7estatdef - 08-10-2011, 07:09 PM
Re: What is this??? need an id.... - by TA Forbes - 08-11-2011, 06:32 PM
