Opinions On Telefunken Opus 7
Hi Mike,
I haven't had that particular set, however, I have a Blaupunkt Florenz 20353 which is my daily player and I recently sent my son a Grundig 2066PX. The BP has 5 speakers not the 7 like the Telefunken. I like the performance of the German units, but am not too crazy about the piano finish which is always cracked somewhere. Have you tried bringing it up at all?? I changed the Selenium rectifiers to bridge rectifiers in both and found practically all the caps to be leaky/bad so they had to go.
Glenn
Happily back in Illinois..not.
Opinions On Telefunken Opus 7 - by Michael Dennis - 08-09-2011, 11:30 AM
Re: Opinions On Telefunken Opus 7 - by Glenn Roberts - 08-09-2011, 01:59 PM
Re: Opinions On Telefunken Opus 7 - by codefox1 - 08-09-2011, 11:31 PM
Eico 232 VTVM Schematic
There are currently 9907 online users. [Complete List]
» 1 Member(s) | 9906 Guest(s)
