Refinishing opinions
OK I am a total Noob when it comes to refinishing cabinets, I'll admit it right up front Icon_lol . I need some expert advice. I have a Grunow cabinet. The sides and face have lacquer chipped and scratched off. The top was pretty bad too. I removed the lacquer on the top and found the wood stained and it appears that very little toner was used in the finishing process. What should I do with the finish I'd really hate to remove all the laquer and respray the entire cabinet, and If I do that I will lose the decals on the face, which are not replaceable. Help!! Icon_smile Thanks, Glenn
Happily back in Illinois..not.
Refinishing opinions - by Glenn Roberts - 08-09-2011, 05:34 PM
Re: Refinishing opinions - by Ron Ramirez - 08-22-2011, 06:23 PM
Re: Refinishing opinions - by TA Forbes - 08-22-2011, 09:11 PM
Re: Refinishing opinions - by Marsupial - 08-22-2011, 11:58 PM
Re: Refinishing opinions - by Glenn Roberts - 08-23-2011, 04:17 AM
Re: Refinishing opinions - by TA Forbes - 08-23-2011, 08:42 PM
There are currently 10533 online users. [Complete List]
» 3 Member(s) | 10530 Guest(s)
