Philco 39-45 restoration: speaker wiring question and more
greenskull Wrote:UPDATE:
Well, I'm seriously considering throwing in the towel after taking the chassis out and looking at all the rotting insulation on the wires. Not a fun job replacing all that.........
No it isn't a fun job, but if you look at it as just one or two wires at a time it gets less intimidating. That is a really nice performing radio and think how proud you'll be being able to save it from the dumpster!
I'm going to e-mail you a link that might give you some inspiration.
Good Luck!
Re: Philco 39-45 restoration: speaker wiring question and mo - by Eliot Ness - 09-12-2011, 05:43 PM
Users browsing this thread: 13 Guest(s)
The speaker table error?
Philco 70 antenna lead
