Transitone 46-200 parts list?
Thanks Chuck. I've purchased from you in the past but in this particular instance I want to see if I can figure out just how badly messed up this radio is before I start putting any more money into it. It may very well end up as a parts donor.
Larry
Transitone 46-200 parts list? - by rocketeer - 08-12-2011, 09:05 PM
Re: Transitone 46-200 parts list? - by rocketeer - 08-12-2011, 10:42 PM
The speaker table error?
Philco 70 antenna lead
