Model 20 Consolette Resto
Sorry to have been so quiet recently. I did notice that the cone has begun to seperate from the surround on my speaker. I will more than likely have to sub in a modern speaker until I can get this one repaired. Question is how do I wire it in? (remember I'm still relatively new).. Thanks for all the great advice so far!
Model 20 Consolette Resto - by badwaxcaps - 07-27-2011, 08:25 PM
Re: Model 20 Consolette Resto - by 7estatdef - 07-27-2011, 10:13 PM
Re: Model 20 Consolette Resto - by Jayce - 07-27-2011, 10:42 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 07-28-2011, 12:11 AM
Re: Model 20 Consolette Resto - by 7estatdef - 07-28-2011, 05:49 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-05-2011, 11:00 AM
Re: Model 20 Consolette Resto - by TA Forbes - 08-05-2011, 12:30 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-05-2011, 07:49 PM
Re: Model 20 Consolette Resto - by TA Forbes - 08-05-2011, 09:57 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-05-2011, 10:51 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-06-2011, 12:50 AM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-06-2011, 01:03 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-06-2011, 07:08 AM
Re: Model 20 Consolette Resto - by Dan - 08-07-2011, 08:24 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-07-2011, 08:43 AM
Re: Model 20 Consolette Resto - by Ron Ramirez - 08-07-2011, 08:46 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-07-2011, 09:19 AM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-12-2011, 11:25 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-13-2011, 09:12 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-22-2011, 12:03 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-22-2011, 08:49 AM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-24-2011, 12:31 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-24-2011, 04:35 PM
Re: Model 20 Consolette Resto - by Chicago Jimmy - 08-24-2011, 06:06 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-24-2011, 07:09 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-24-2011, 09:36 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-24-2011, 11:53 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-25-2011, 11:19 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 12:39 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-26-2011, 04:11 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 06:44 PM
Re: Model 20 Consolette Resto - by Ron Ramirez - 08-26-2011, 07:08 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 07:16 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 07:18 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-26-2011, 07:26 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 11:11 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 11:13 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-27-2011, 12:37 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-28-2011, 09:56 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-29-2011, 01:33 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-30-2011, 07:54 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-30-2011, 05:08 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-30-2011, 07:57 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-31-2011, 02:30 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-31-2011, 05:19 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-31-2011, 07:48 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-31-2011, 09:19 PM
There are currently 8693 online users. [Complete List]
» 2 Member(s) | 8691 Guest(s)
