Mystery radio - identification, etc. sought
thanks. My mom only heard what she thought was station ID once so she either misheard 880 going fast or, perhaps, it wasn't the station ID at all she heard.
Where does one find replacement dials? I don't know that they'd be interested if it's a lot of money but they enjoy just having it around.
Re: Mystery radio - identification, etc. sought - by dtf955 - 08-13-2011, 11:13 AM
There are currently 7674 online users. [Complete List]
» 4 Member(s) | 7670 Guest(s)
AvatarAvatarAvatarAvatar
