Radio found in trash.
Wow! Neat radio!
Should you need a plastic dial cover for it Mark Palmquist at Retro Radio Repair should either have one or can make one if you send him your escutchion.
Radio found in trash. - by Jayce - 06-06-2011, 04:57 PM
Re: Radio found in trash. - by Ron Ramirez - 06-07-2011, 09:08 PM
Re: Radio found in trash. - by Jayce - 06-08-2011, 08:54 PM
Re: Radio found in trash. - by Arran - 06-10-2011, 01:22 AM
Re: Radio found in trash. - by Music in a bottle - 06-20-2011, 05:14 PM
Re: Radio found in trash. - by Art Hoch - 08-13-2011, 03:19 PM
Re: Radio found in trash. - by Eliot Ness - 08-13-2011, 10:37 PM
Re: Radio found in trash. - by Dave - 08-14-2011, 09:11 PM
Re: Radio found in trash. - by TA Forbes - 08-14-2011, 11:52 PM
