116x Rectifier light show
Disassembled the tuning mechanism and found the veneer assembly rubbing on the support bracket. Everything working great now. Thanks for the advice. Gary
116x Rectifier light show - by garyh1 - 09-13-2011, 11:50 PM
Re: 116x Rectifier light show - by codefox1 - 09-14-2011, 09:10 AM
Re: 116x Rectifier light show - by garyh1 - 09-17-2011, 10:32 AM
Re: 116x Rectifier light show - by TA Forbes - 09-17-2011, 12:25 PM
Re: 116x Rectifier light show - by garyh1 - 09-17-2011, 07:16 PM
Re: 116x Rectifier light show - by garyh1 - 09-17-2011, 07:38 PM
Re: 116x Rectifier light show - by Marsupial - 09-18-2011, 01:07 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 01:29 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 03:04 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 03:06 AM
Re: 116x Rectifier light show - by Ron Ramirez - 09-18-2011, 07:05 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 11:41 AM
Re: 116x Rectifier light show - by TA Forbes - 09-18-2011, 04:55 PM
Re: 116x Rectifier light show - by Ron Ramirez - 09-18-2011, 04:56 PM
Re: 116x Rectifier light show - by TA Forbes - 09-18-2011, 07:03 PM
Re: 116x Rectifier light show - by thirtiesradio - 09-19-2011, 02:35 AM
Re: 116x Rectifier light show - by Glenn Roberts - 09-19-2011, 04:15 AM
Re: 116x Rectifier light show - by codefox1 - 09-19-2011, 10:43 AM
Re: 116x Rectifier light show - by garyh1 - 09-19-2011, 01:29 PM
Re: 116x Rectifier light show - by TA Forbes - 09-19-2011, 01:53 PM
Re: 116x Rectifier light show - by thirtiesradio - 09-20-2011, 12:18 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5875 online users. [Complete List]
» 1 Member(s) | 5874 Guest(s)
