Philco 20 restoration state: need the voltage chart
yes those are carbon resistors, and I ordered everything from Mouser yesterday. All 5 of them.
Plus, what bugs me (I am sure it does not matter) - the mica cap bypassing the detector's (24) anode, which is supposed to be 250pF, when disconnected and measured, was 400pF.
I thought mica caps were long-term stable. I am sure this does not matter much in this case, but ordered another mica cap for the 250pF just in case.
I want to have all resistors right, so to compare the DC voltage values with the chart first, otherwise it becomes a guessing game. My non-tube troubleshooting experience tells me "get all values right, then troubleshoot". Usually makes all that much easier.
The last thing I will check is those potted caps and the two caps in metal boxes (so far I measured two of the potted caps I could easily unsolder, and their values were right where they are supposed to be). Hopefully the rest is like this also.
Re: Philco 20 restoration state: need the voltage chart - by morzh - 10-28-2011, 11:44 AM
91H Code 126 Restore
Philco 70 antenna lead
