Philco model 511
7estatdef Wrote:Well it sounds like it's shorted.Unfortunately you will have to find a set that has the same tube line up so you'll have the proper filament voltages for all of the tubes. There is a model 87 up on epay but I don't think it has all the voltages you need.
Do you know where I can get a modern replacement for this transformer or do you think I need to have this transformer rewound and where would I get rewound?
Thank you Terry
Philco model 511 - by radionut1929 - 08-14-2011, 02:42 AM
Re: Philco model 511 - by 7estatdef - 08-15-2011, 07:33 AM
Re: Philco model 511 - by radionut1929 - 08-15-2011, 10:16 PM
Re: Philco model 511 - by 7estatdef - 08-15-2011, 10:24 PM
Re: Philco model 511 - by codefox1 - 08-15-2011, 10:40 PM
Re: Philco model 511 - by radionut1929 - 08-16-2011, 12:18 AM
Re: Philco model 511 - by radionut1929 - 08-16-2011, 12:22 AM
Re: Philco model 511 - by Ron Ramirez - 08-16-2011, 07:58 AM
Re: Philco model 511 - by 7estatdef - 08-16-2011, 06:39 PM
Re: Philco model 511 - by gvel - 08-16-2011, 08:34 PM
Re: Philco model 511 - by radionut1929 - 08-18-2011, 06:11 AM
Re: Philco model 511 - by Ron Ramirez - 08-18-2011, 07:47 AM
Re: Philco model 511 - by radionut1929 - 08-21-2011, 05:40 PM
Re: Philco model 511 - by codefox1 - 08-21-2011, 05:52 PM
Re: Philco model 511 - by Ron Ramirez - 08-21-2011, 07:45 PM
Re: Philco model 511 - by radionut1929 - 08-22-2011, 03:12 AM
Re: Philco model 511 - by 7estatdef - 08-22-2011, 03:15 PM
Re: Philco model 511 - by Ron Ramirez - 08-22-2011, 03:30 PM
Re: Philco model 511 - by 7estatdef - 08-22-2011, 03:56 PM
Re: Philco model 511 - by Ron Ramirez - 08-22-2011, 03:58 PM
Re: Philco model 511 - by Eliot Ness - 08-22-2011, 05:37 PM
Re: Philco model 511 - by radionut1929 - 08-23-2011, 03:29 AM
Re: Philco model 511 - by Ron Ramirez - 08-24-2011, 03:16 PM
Re: Philco model 511 - by radionut1929 - 08-30-2011, 11:27 PM
Re: Philco model 511 - by Arran - 08-30-2011, 11:46 PM
Re: Philco model 511 - by Ron Ramirez - 08-31-2011, 11:05 AM
Re: Philco model 511 - by radionut1929 - 09-12-2011, 02:06 AM
Re: Philco model 511 - by Ron Ramirez - 09-12-2011, 10:37 AM
Re: Philco model 511 - by TA Forbes - 09-12-2011, 09:21 PM
Re: Philco model 511 - by radionut1929 - 09-12-2011, 11:33 PM
Re: Philco model 511 - by radionut1929 - 10-28-2011, 12:21 AM
Re: Philco model 511 - by jerryhawthorne - 10-30-2011, 01:26 PM
Re: Philco model 511 - by Ron Ramirez - 10-31-2011, 06:57 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3441 online users. [Complete List]
» 2 Member(s) | 3439 Guest(s)
