Philco model 511
Trying to find a replacement for it is going to be tough. You'll need one with 2,5v windings one for the 80 &one for the audio tubes, a 2.5v winding for the 27 tube, and a 1.5v winding for the 26's. The Atwater Kent mod 40 uses one but it's in a can full of tar with two chokes and some caps. They can be had cheap but will be some work to get it apart and in the 511.
I hate to disagree with a fellow Phourm member but I wouldn't think of using a doubler to generate the needed HV across half the HV winding. Bad idea. What you are asking a half of burned up transformer is to deliver twice the current across one half of the HV winding. It's asking for trouble.
For a replacement look in the resources section. These a company that will build one to your spec. Will be pricey like $100-150. Rewinding would be about the same.
Sorry OM
Philco model 511 - by radionut1929 - 08-14-2011, 02:42 AM
Re: Philco model 511 - by 7estatdef - 08-15-2011, 07:33 AM
Re: Philco model 511 - by radionut1929 - 08-15-2011, 10:16 PM
Re: Philco model 511 - by 7estatdef - 08-15-2011, 10:24 PM
Re: Philco model 511 - by codefox1 - 08-15-2011, 10:40 PM
Re: Philco model 511 - by radionut1929 - 08-16-2011, 12:18 AM
Re: Philco model 511 - by radionut1929 - 08-16-2011, 12:22 AM
Re: Philco model 511 - by Ron Ramirez - 08-16-2011, 07:58 AM
Re: Philco model 511 - by 7estatdef - 08-16-2011, 06:39 PM
Re: Philco model 511 - by gvel - 08-16-2011, 08:34 PM
Re: Philco model 511 - by radionut1929 - 08-18-2011, 06:11 AM
Re: Philco model 511 - by Ron Ramirez - 08-18-2011, 07:47 AM
Re: Philco model 511 - by radionut1929 - 08-21-2011, 05:40 PM
Re: Philco model 511 - by codefox1 - 08-21-2011, 05:52 PM
Re: Philco model 511 - by Ron Ramirez - 08-21-2011, 07:45 PM
Re: Philco model 511 - by radionut1929 - 08-22-2011, 03:12 AM
Re: Philco model 511 - by 7estatdef - 08-22-2011, 03:15 PM
Re: Philco model 511 - by Ron Ramirez - 08-22-2011, 03:30 PM
Re: Philco model 511 - by 7estatdef - 08-22-2011, 03:56 PM
Re: Philco model 511 - by Ron Ramirez - 08-22-2011, 03:58 PM
Re: Philco model 511 - by Eliot Ness - 08-22-2011, 05:37 PM
Re: Philco model 511 - by radionut1929 - 08-23-2011, 03:29 AM
Re: Philco model 511 - by Ron Ramirez - 08-24-2011, 03:16 PM
Re: Philco model 511 - by radionut1929 - 08-30-2011, 11:27 PM
Re: Philco model 511 - by Arran - 08-30-2011, 11:46 PM
Re: Philco model 511 - by Ron Ramirez - 08-31-2011, 11:05 AM
Re: Philco model 511 - by radionut1929 - 09-12-2011, 02:06 AM
Re: Philco model 511 - by Ron Ramirez - 09-12-2011, 10:37 AM
Re: Philco model 511 - by TA Forbes - 09-12-2011, 09:21 PM
Re: Philco model 511 - by radionut1929 - 09-12-2011, 11:33 PM
Re: Philco model 511 - by radionut1929 - 10-28-2011, 12:21 AM
Re: Philco model 511 - by jerryhawthorne - 10-30-2011, 01:26 PM
Re: Philco model 511 - by Ron Ramirez - 10-31-2011, 06:57 PM
91H Code 126 Restore
Philco 70 antenna lead
