What is this doofungus?
It is sort of original - sort of in that I see it has the Sprague name on it, so it is a replacement for the original Philco part.
This cap and coil combination was intended to act as a wave trap at the set's IF frequency, 455 kc, and to shunt stray IF currents to ground.
You can read more about it on Chuck's site.
http://www.philcorepairbench.com/tips/svctip37.htm
In replacing this part, you can either replace it with a 0.22 uF cap and not worry about the wires wrapped around it, or you can wrap a new wire around the new cap if you wish. You will see how it should be wound when you undo the original.
What is this doofungus? - by rocketeer - 08-16-2011, 11:29 PM
Re: What is this doofungus? - by Ron Ramirez - 08-17-2011, 07:55 AM
Re: What is this doofungus? - by Dan Walker - 08-17-2011, 11:04 AM
Re: What is this doofungus? - by rocketeer - 08-17-2011, 07:53 PM
Re: What is this doofungus? - by rocketeer - 08-20-2011, 10:07 PM
Re: What is this doofungus? - by TexMac - 08-27-2011, 02:57 AM
Re: What is this doofungus? - by Arran - 08-29-2011, 01:13 AM
Re: What is this doofungus? - by exray - 08-30-2011, 05:58 PM
Re: What is this doofungus? - by codefox1 - 08-30-2011, 10:27 PM
Re: What is this doofungus? - by exray - 08-31-2011, 07:57 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7107 online users. [Complete List]
» 2 Member(s) | 7105 Guest(s)
