philco 42-350
hi fellow philco fans,looking for some resistance and voltage specs on the power trans,this one gets hot and smells bad after just a minute of operation,panel lights go dim at the same time,no specs on nostalgia air,i've measured the primary at 14 ohms ,filters are replaced.can i remove all the tubes and plug in again and see if the same thing happens?? all tubes tested good on my rpc-323,don't trust my sencore mighty mite anymore after misleading me on a 35z5,tested good on it but didn't work in radio which caused unnecesary troubleshooting,thanks for the help,phil
philco 42-350 - by philco fan - 07-16-2006, 03:17 PM
[No subject] - by Chuck Schwark - 07-16-2006, 03:26 PM
42-350 - by philco fan - 07-16-2006, 07:00 PM
[No subject] - by Chuck Schwark - 07-16-2006, 11:08 PM
[No subject] - by philco fan - 07-16-2006, 11:10 PM
There are currently 8298 online users. [Complete List]
» 2 Member(s) | 8296 Guest(s)
