Caps List?
Dark, Welcome to the Philco phorum!
I don't think there is any list that gives you a list to buy from a vendor the specific caps you need for that model. You need to do some research on your model at nostalgiaair.org.There you can search for your schematic and parts list and figure out what you need.Then you need to find a vendor or store that sells them. We buy from many different places. Radio daze,just radios,radio antiques,etc.
Caps List? - by Dark High - 08-17-2011, 09:52 AM
Re: Caps List? - by Chicago Jimmy - 08-17-2011, 05:41 PM
Re: Caps List? - by Marsupial - 08-17-2011, 10:38 PM
Re: Caps List? - by Dark High - 08-18-2011, 11:27 AM
Re: Caps List? - by exray - 08-18-2011, 11:49 AM
Re: Caps List? - by dcastor - 08-18-2011, 01:00 PM
Re: Caps List? - by Dark High - 08-19-2011, 11:28 AM
Re: Caps List? - by Ron Ramirez - 08-19-2011, 01:34 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6863 online users. [Complete List]
» 1 Member(s) | 6862 Guest(s)
