Electrocution Risk?
I'm starting to work on my Philco 40-180 I got recently, but before I started messing around with the insides, what are the risks? If it's unplugged, am I in the clear? Will anything discharge when I touch it? I know some old tube TVs can still hold a charge even if it's unplugged. Just checking.
Dark
Electrocution Risk? - by Dark High - 08-17-2011, 05:44 PM
Re: Electrocution Risk? - by codefox1 - 08-17-2011, 06:01 PM
Re: Electrocution Risk? - by 37silverstreak - 08-17-2011, 06:29 PM
Re: Electrocution Risk? - by Dark High - 08-18-2011, 11:09 AM
Re: Electrocution Risk? - by dcastor - 08-18-2011, 01:06 PM
Re: Electrocution Risk? - by Arran - 08-30-2011, 11:29 PM
Re: Electrocution Risk? - by ipwizard - 09-27-2011, 04:49 PM
Re: Electrocution Risk? - by codefox1 - 09-27-2011, 07:52 PM
Re: Electrocution Risk? - by cwysong - 09-27-2011, 09:29 PM
The speaker table error?
Philco 70 antenna lead
