Philco 96 Whooped boy
Well guys is this radio worth the effort to restore it? http://community.webshots.com/album/482082943SEJFTX It needs TLC in the biggest way. I can steam the top veneer off and use the best sections to replace the missing lower veneer sections and I can glue the delaminated veneer back and glue the frame and clamp it back so that it is solid again. I am not sure what to do about the missing lower trim pieces, maybe make some more simplier ones and see how that looks. Thumbs up for restore or Landfill fodder???
Philco 96 Whooped boy - by 49Stude63 - 10-20-2005, 10:28 PM
[No subject] - by Chuck Schwark - 10-20-2005, 10:49 PM
[No subject] - by Jerry Huelsbeck - 10-20-2005, 10:54 PM
[No subject] - by 49Stude63 - 10-20-2005, 11:04 PM
[No subject] - by Ron Ramirez - 10-20-2005, 11:27 PM
[No subject] - by 49Stude63 - 10-21-2005, 11:31 PM
[No subject] - by Chuck Schwark - 10-21-2005, 11:42 PM
[No subject] - by 49Stude63 - 11-20-2005, 04:05 PM
[No subject] - by Ron Ramirez - 11-27-2005, 10:13 PM
[No subject] - by Ron Ramirez - 11-29-2005, 06:54 PM
