philco 42-350
Philco Part No. 32-8183
SEC = 510 VCT @ 50 ma.
REC = 6.4 VAC @ 3.5 amp.
H = 3-1/8"
W = 2-1/4"
L = 2-1/2"
Mtg centers = 2-1/8" x 1-21/32"
philco 42-350 - by philco fan - 07-16-2006, 03:17 PM
[No subject] - by Chuck Schwark - 07-16-2006, 03:26 PM
42-350 - by philco fan - 07-16-2006, 07:00 PM
[No subject] - by Chuck Schwark - 07-16-2006, 11:08 PM
[No subject] - by philco fan - 07-16-2006, 11:10 PM
There are currently 7010 online users. [Complete List]
» 1 Member(s) | 7009 Guest(s)
