Caps List?
Thanks for your help. When I do my recapping, I'll see if I can make a list of what I took out of the radio and then the corresponding replacement cap I installed and where I bought it. I've got the schematics and the parts it has listed.
I know it could be more time consuming and the caps won't match up one to one as far as the specs go, but I'll use whatever the closest cap I can find. I just think it'd be helpful to look at a list for a certain radio and order a set of caps and then get to work. That way it should cut down on multiple trips to the electronics store or online orders for parts.
Caps List? - by Dark High - 08-17-2011, 09:52 AM
Re: Caps List? - by Chicago Jimmy - 08-17-2011, 05:41 PM
Re: Caps List? - by Marsupial - 08-17-2011, 10:38 PM
Re: Caps List? - by Dark High - 08-18-2011, 11:27 AM
Re: Caps List? - by exray - 08-18-2011, 11:49 AM
Re: Caps List? - by dcastor - 08-18-2011, 01:00 PM
Re: Caps List? - by Dark High - 08-19-2011, 11:28 AM
Re: Caps List? - by Ron Ramirez - 08-19-2011, 01:34 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
