41-250 bandswitch lamp
There was a posting on 10/20/07 describing how the 41-250 bandswitch operated. The part I need help on is exactly where and how is the spring attached as mine is missing this part. I understand the spring is approx. 1/8" in dia. and about 7/8" long including the loops. Any help will be greatly appreciated.
41-250 bandswitch lamp - by williec - 08-19-2011, 09:38 AM
RE: 41-250 bandswitch lamp - by GACTVDX - 09-18-2014, 01:06 AM
There are currently 9202 online users. [Complete List]
» 3 Member(s) | 9199 Guest(s)
