Flea market find
I picked up this model 89B code 123 at a local fire company fund raiser flea market yesterday. I'm not into the cathedrals but there was a young kid who grabbed two tube amps and was eyeing up the Philco who gave me the impression it might be something he could stick a cd in. He already had the amps but at least I was able to save the Philco. It's a bit rough but all there.
[Image: http://i863.photobucket.com/albums/ab191...o_89-1.jpg]
[Image: http://i863.photobucket.com/albums/ab191...o_89-2.jpg]
Larry
Flea market find - by rocketeer - 08-20-2011, 10:00 PM
Re: Flea market find - by TA Forbes - 08-20-2011, 10:18 PM
Re: Flea market find - by Chuck Schwark - 09-04-2011, 12:46 PM
Re: Flea market find - by Michael Dennis - 09-04-2011, 01:02 PM
Re: Flea market find - by Ron Ramirez - 09-04-2011, 01:07 PM
Re: Flea market find - by Michael Dennis - 09-04-2011, 01:15 PM
Re: Flea market find - by rocketeer - 09-04-2011, 05:01 PM
Re: Flea market find - by Ron Ramirez - 09-04-2011, 05:18 PM
There are currently 9358 online users. [Complete List]
» 2 Member(s) | 9356 Guest(s)
