What is this doofungus?
I replaced it with a .22 cap and rewound it with the wire. Other than the squeeky little speaker she plays really well. Awaiting a new dial cover from Palmquist before I put it back together.
Larry
What is this doofungus? - by rocketeer - 08-16-2011, 11:29 PM
Re: What is this doofungus? - by Ron Ramirez - 08-17-2011, 07:55 AM
Re: What is this doofungus? - by Dan Walker - 08-17-2011, 11:04 AM
Re: What is this doofungus? - by rocketeer - 08-17-2011, 07:53 PM
Re: What is this doofungus? - by rocketeer - 08-20-2011, 10:07 PM
Re: What is this doofungus? - by TexMac - 08-27-2011, 02:57 AM
Re: What is this doofungus? - by Arran - 08-29-2011, 01:13 AM
Re: What is this doofungus? - by exray - 08-30-2011, 05:58 PM
Re: What is this doofungus? - by codefox1 - 08-30-2011, 10:27 PM
Re: What is this doofungus? - by exray - 08-31-2011, 07:57 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7600 online users. [Complete List]
» 3 Member(s) | 7597 Guest(s)
