Just snaged on CL
Tnx $45 was just the asking price...
There are some other nice sets that have been on the philly CL. 90 console, 630 or 37-630 console and some others. All pretty reasonable around $75. I jumped in the 80 as soon as I saw it, about an hour after it was listed.
Just snaged on CL - by 7estatdef - 08-20-2011, 10:29 PM
Re: Just snaged on CL - by TA Forbes - 08-21-2011, 03:42 AM
Re: Just snaged on CL - by 7estatdef - 08-21-2011, 08:56 AM
Re: Just snaged on CL - by TA Forbes - 08-21-2011, 08:06 PM
Re: Just snaged on CL - by 7estatdef - 08-22-2011, 11:11 AM
Re: Just snaged on CL - by Chicago Jimmy - 08-22-2011, 04:52 PM
Re: Just snaged on CL - by Ron Ramirez - 08-22-2011, 05:56 PM
Re: Just snaged on CL - by 7estatdef - 08-22-2011, 06:10 PM
There are currently 10538 online users. [Complete List]
» 3 Member(s) | 10535 Guest(s)
