Need Grille cloth help
Assuming you mean your 87 and 95 are both lowboys with the fancy grillework inside the scalloped opening, as shown here:
http://www.philcoradio.com/gallery/1929b.htm#c
here are my recommendations:
87, 95, 20: Pattern #52.
21 cathedral: Pattern #1.
80B, 81B: Pattern #10.
37-116: Pattern #3.
Good luck...get it fast while it's still available.
Need Grille cloth help - by 7estatdef - 08-22-2011, 03:37 PM
Re: Need Grille cloth help - by Ron Ramirez - 08-22-2011, 03:55 PM
Re: Need Grille cloth help - by 7estatdef - 08-22-2011, 04:37 PM
Re: Need Grille cloth help - by Ron Ramirez - 08-22-2011, 06:05 PM
Re: Need Grille cloth help - by SamTanner - 09-14-2011, 04:03 PM
Re: Need Grille cloth help - by Ron Ramirez - 09-14-2011, 10:26 PM
Re: Need Grille cloth help - by SamTanner - 09-14-2011, 10:36 PM
Re: Need Grille cloth help - by Ron Ramirez - 09-14-2011, 10:40 PM
Re: Need Grille cloth help - by Arran - 09-15-2011, 07:47 PM
There are currently 9662 online users. [Complete List]
» 3 Member(s) | 9659 Guest(s)
