Philco 90 - Which Version?
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Well, I found one sooner than I expected. A friend knew I was looking for one and called me to tell me he had it. He was asking $275 and I thought that sounded reasonable. I went to look at it today and brought it home for $200. It is the middle version with the single 47 and the metal escutcheon. I am posting a couple of pictures here and Ron ,maybe you or someone else can tell me if this is the correct grille cloth. It is somewhat worn and looks like it has been in there awhile.
If not the correct grille cloth can you tell me which one of John's products is the correct one? It looks like maybe #1 or #2 in his online catalog.
Frank
Philco 90 - Which Version? - by francois8890 - 08-18-2011, 10:47 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 08:17 AM
Re: Philco 90 - Which Version? - by dcastor - 08-19-2011, 01:02 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 01:29 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-19-2011, 01:57 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 02:05 PM
Re: Philco 90 - Which Version? - by Eliot Ness - 08-19-2011, 04:51 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-19-2011, 08:36 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 09:18 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-19-2011, 09:24 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 09:30 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-23-2011, 07:04 PM
Re: Philco 90 - Which Version? - by TA Forbes - 08-23-2011, 08:35 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-24-2011, 07:52 AM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-24-2011, 08:06 AM
Re: Philco 90 - Which Version? - by Eliot Ness - 08-24-2011, 08:22 AM
Re: Philco 90 - Which Version? - by francois8890 - 08-24-2011, 09:55 PM
Re: Philco 90 - Which Version? - by thirtiesradio - 08-25-2011, 03:21 AM
There are currently 10444 online users. [Complete List]
» 2 Member(s) | 10442 Guest(s)
