Philco 16B
Hi Tom
The shouldered 16B sets do seem to be a bit less common than the "Deco" 16B tombstones. Philco also sold less of the shouldered 16B (10,400) than the two versions of the "Deco" or "housetop" variety (combined total of 18,147 for both varieties).
Philco 16B - by thirtiesradio - 08-13-2011, 03:20 AM
Re: Philco 16B - by TA Forbes - 08-13-2011, 11:33 PM
Re: Philco 16B - by thirtiesradio - 08-14-2011, 12:11 AM
Re: Philco 16B - by TA Forbes - 08-14-2011, 01:32 PM
Re: Philco 16B - by Ron Ramirez - 08-14-2011, 06:33 PM
Re: Philco 16B - by TA Forbes - 08-14-2011, 11:39 PM
Re: Philco 16B - by thirtiesradio - 08-23-2011, 05:29 PM
Re: Philco 16B - by thirtiesradio - 08-23-2011, 05:34 PM
Re: Philco 16B - by Ron Ramirez - 08-23-2011, 08:07 PM
Re: Philco 16B - by TA Forbes - 08-23-2011, 08:29 PM
Re: Philco 16B - by thirtiesradio - 08-24-2011, 11:06 AM
Re: Philco 16B - by TA Forbes - 08-24-2011, 09:32 PM
Re: Philco 16B - by thirtiesradio - 08-25-2011, 03:06 AM
Re: Philco 16B - by BDM - 12-07-2011, 06:58 PM
Re: Philco 16B - by TA Forbes - 12-07-2011, 11:10 PM
Philco 91 Tuning Condenser
There are currently 4907 online users. [Complete List]
» 2 Member(s) | 4905 Guest(s)
