Philco 90 - Which Version?
francois8890 Wrote:...Ron ,maybe you or someone else can tell me if this is the correct grille cloth.
I can't really tell from the photo. If it matches pattern #1 from John at Radio Grille Cloth Headquarters, then it is the correct pattern.
Congratulations on your find! You ended up with just what you wanted, right? A 90 that has AVC and a brass escutcheon.
Philco 90 - Which Version? - by francois8890 - 08-18-2011, 10:47 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 08:17 AM
Re: Philco 90 - Which Version? - by dcastor - 08-19-2011, 01:02 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 01:29 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-19-2011, 01:57 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 02:05 PM
Re: Philco 90 - Which Version? - by Eliot Ness - 08-19-2011, 04:51 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-19-2011, 08:36 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 09:18 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-19-2011, 09:24 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 09:30 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-23-2011, 07:04 PM
Re: Philco 90 - Which Version? - by TA Forbes - 08-23-2011, 08:35 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-24-2011, 07:52 AM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-24-2011, 08:06 AM
Re: Philco 90 - Which Version? - by Eliot Ness - 08-24-2011, 08:22 AM
Re: Philco 90 - Which Version? - by francois8890 - 08-24-2011, 09:55 PM
Re: Philco 90 - Which Version? - by thirtiesradio - 08-25-2011, 03:21 AM
There are currently 10554 online users. [Complete List]
» 2 Member(s) | 10552 Guest(s)
