Rookie Question - Radio Alignment
I'm not familiar too much with that particular model, but don't go looking too hard for a replacement screw. It's very possible that your model didn't use one in that position.
You said you tuned to a low frequency - what was it? Ideally, this works better when tuned to something at the higher end of the dial. Try the process again tuning in something at the upper end and see if it works better. Good luck!
Bill
Sent from my Pentium II on the AT&T Dial Network
Rookie Question - Radio Alignment - by kstesney - 07-20-2006, 08:06 AM
[No subject] - by Bill Hutchinson - 07-20-2006, 04:43 PM
[No subject] - by kstesney - 07-20-2006, 07:58 PM
[No subject] - by Bill Hutchinson - 07-20-2006, 10:12 PM
Better... but still have a way to go - by kstesney - 07-24-2006, 02:19 PM
[No subject] - by Chuck Schwark - 07-24-2006, 02:45 PM
Eureka! - by kstesney - 08-06-2006, 12:45 PM
[No subject] - by Chuck Schwark - 08-06-2006, 09:30 PM
Eico 232 VTVM Schematic
There are currently 8581 online users. [Complete List]
» 2 Member(s) | 8579 Guest(s)
