Philco 90 - Which Version?
Yes Ron, That was what I was looking for initially although I got a little conflicted there when I was studying it thinking I might want the late version but the price coupled with the overall good condition convinced me to go ahead with this one.
I have a piece of the #1 grille cloth from John that I was going to put in my Zenith 10S130 but I may order the #2 and use for it instead if the #1 is correct for the 90.
Since I am going to probably be displaying bot of those sets pretty close to each other I would rather that the grill cloth not be identical on both sets.
thanks,
Frank
Philco 90 - Which Version? - by francois8890 - 08-18-2011, 10:47 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 08:17 AM
Re: Philco 90 - Which Version? - by dcastor - 08-19-2011, 01:02 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 01:29 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-19-2011, 01:57 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 02:05 PM
Re: Philco 90 - Which Version? - by Eliot Ness - 08-19-2011, 04:51 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-19-2011, 08:36 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 09:18 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-19-2011, 09:24 PM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-19-2011, 09:30 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-23-2011, 07:04 PM
Re: Philco 90 - Which Version? - by TA Forbes - 08-23-2011, 08:35 PM
Re: Philco 90 - Which Version? - by francois8890 - 08-24-2011, 07:52 AM
Re: Philco 90 - Which Version? - by Ron Ramirez - 08-24-2011, 08:06 AM
Re: Philco 90 - Which Version? - by Eliot Ness - 08-24-2011, 08:22 AM
Re: Philco 90 - Which Version? - by francois8890 - 08-24-2011, 09:55 PM
Re: Philco 90 - Which Version? - by thirtiesradio - 08-25-2011, 03:21 AM
There are currently 9915 online users. [Complete List]
» 2 Member(s) | 9913 Guest(s)
