  • 1 Vote(s) - 5 Average
Philco 38-7 CS restoration
Thanks! I'm not crazy about applying new veneer, but luckily this was a small job and went smoothly.
I haven't finished restoring it electrically yet. So far, I have cleaned the gunk out of the mechanism and re-lubed it. It operates smoothly now and I hope electrically too. Worst case scenario I have a spare cone-centric assembly salvaged from a 38-4 I can use.
Philco 38-7 CS restoration - by Bob Andersen - 08-24-2011, 07:02 PM
RE: Philco 38-7 CS restoration - by Rubrburnr - 01-01-2013, 09:16 PM
RE: Philco 38-7 CS restoration - by Bob Andersen - 01-01-2013, 09:33 PM
RE: Philco 38-7 CS restoration - by Rubrburnr - 01-01-2013, 09:54 PM
RE: Philco 38-7 CS restoration - by Bob Andersen - 01-02-2013, 09:29 PM
RE: Philco 38-7 CS restoration - by TA Forbes - 01-02-2013, 10:40 PM
RE: Philco 38-7 CS restoration - by Bob Andersen - 08-01-2014, 11:43 PM
RE: Philco 38-7 CS restoration - by klondike98 - 08-02-2014, 09:39 AM
RE: Philco 38-7 CS restoration - by PhilcoJohn - 08-03-2014, 08:32 AM
RE: Philco 38-7 CS restoration - by Bob Andersen - 08-03-2014, 02:28 PM
RE: Philco 38-7 CS restoration - by Geoff - 08-09-2014, 12:34 AM
RE: Philco 38-7 CS restoration - by Bob Andersen - 10-17-2014, 12:11 PM
RE: Philco 38-7 CS restoration - by Bob Andersen - 10-17-2014, 12:14 PM
RE: Philco 38-7 CS restoration - by Eliot Ness - 10-17-2014, 12:21 PM
RE: Philco 38-7 CS restoration - by morzh - 10-17-2014, 04:02 PM
RE: Philco 38-7 CS restoration - by PhilcoJohn - 10-22-2014, 09:48 AM
Re: Philco 38-7 CS restoration - by Bob Andersen - 08-24-2011, 07:07 PM
Re: Philco 38-7 CS restoration - by TA Forbes - 08-24-2011, 09:38 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 08-24-2011, 10:15 PM
Re: Philco 38-7 CS restoration - by Arran - 08-25-2011, 10:36 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 08-26-2011, 02:01 AM
Re: Philco 38-7 CS restoration - by Arran - 08-27-2011, 01:10 AM
Re: Philco 38-7 CS restoration - by TA Forbes - 08-27-2011, 03:49 PM
Re: Philco 38-7 CS restoration - by Ron Ramirez - 08-27-2011, 04:13 PM
Re: Philco 38-7 CS restoration - by Arran - 08-28-2011, 12:54 AM
Re: Philco 38-7 CS restoration - by Bob Andersen - 08-28-2011, 01:35 PM
Re: Philco 38-7 CS restoration - by codefox1 - 08-28-2011, 02:30 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-06-2011, 11:20 PM
Re: Philco 38-7 CS restoration - by Ron Ramirez - 09-11-2011, 10:35 AM
Re: Philco 38-7 CS restoration - by Steve Davis - 09-11-2011, 11:17 AM
Re: Philco 38-7 CS restoration - by Arran - 09-11-2011, 07:38 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-12-2011, 12:20 AM
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-14-2011, 09:09 PM
Re: Philco 38-7 CS restoration - by TA Forbes - 09-14-2011, 10:28 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-15-2011, 03:03 AM
Re: Philco 38-7 CS restoration - by TA Forbes - 09-15-2011, 10:33 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-15-2011, 10:56 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-23-2011, 05:47 PM
Re: Philco 38-7 CS restoration - by TA Forbes - 09-23-2011, 10:06 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-24-2011, 12:34 AM
Re: Philco 38-7 CS restoration - by TA Forbes - 09-24-2011, 10:37 PM
Re: Philco 38-7 CS restoration - by codefox1 - 09-25-2011, 10:05 AM
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-26-2011, 02:02 AM
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-27-2011, 01:42 AM
Re: Philco 38-7 CS restoration - by Bob Andersen - 10-03-2011, 12:28 AM
Re: Philco 38-7 CS restoration - by Bob Andersen - 10-04-2011, 06:51 PM
Re: Philco 38-7 CS restoration - by ipwizard - 10-05-2011, 04:11 PM
Re: Philco 38-7 CS restoration - by TA Forbes - 10-05-2011, 11:02 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 10-09-2011, 11:58 PM
Re: Philco 38-7 CS restoration - by Bob Andersen - 10-12-2011, 12:55 AM
Re: Philco 38-7 CS restoration - by Ron Ramirez - 10-12-2011, 05:18 AM
Re: Philco 38-7 CS restoration - by Arran - 10-17-2011, 12:11 AM
Re: Philco 38-7 CS restoration - by Bob Andersen - 10-17-2011, 04:31 PM
Re: Philco 38-7 CS restoration - by Arran - 10-18-2011, 01:47 AM
