Tapped tone compensated volume control
Guys, thanks very much. It is about what I expected. This is what I have heard in my local club. I will keep Mark Oppat in mind also.
Don
Re: Tapped tone compensated volume control - by Don Ferguson - 08-26-2011, 09:20 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5560 online users. [Complete List]
» 1 Member(s) | 5559 Guest(s)
