Tapped tone compensated volume control
Well you could approximate the tap (which I assume the link that is broken,) with fixed resistors midrange, and you might be OK. You did do Deoxit? Taps on pots were always a little tricky, some reacted with sweating of the contact, more violent means are possible. Were they
trying to create a "loudness" or damping control for AM radio way back then?
Re: Tapped tone compensated volume control - by codefox1 - 08-26-2011, 09:43 PM
91H Code 126 Restore
Philco 70 antenna lead
