CAN'T FIGURE OUT THE MODEL
Neither one. It's shown on "radiomuseum.com" Just type in Philco 38L and there it is. I'm sure you can get a copy off their site.
CAN'T FIGURE OUT THE MODEL - by williec - 08-25-2011, 09:54 PM
Re: CAN'T FIGURE OUT THE MODEL - by Ron Ramirez - 08-25-2011, 10:13 PM
Re: CAN'T FIGURE OUT THE MODEL - by williec - 08-26-2011, 09:22 AM
Re: CAN'T FIGURE OUT THE MODEL - by Ron Ramirez - 08-26-2011, 12:24 PM
Re: CAN'T FIGURE OUT THE MODEL - by williec - 08-26-2011, 02:41 PM
Re: CAN'T FIGURE OUT THE MODEL - by Ron Ramirez - 08-26-2011, 03:00 PM
Re: CAN'T FIGURE OUT THE MODEL - by williec - 08-26-2011, 03:08 PM
Re: CAN'T FIGURE OUT THE MODEL - by Natalia - 08-26-2011, 03:54 PM
Re: CAN'T FIGURE OUT THE MODEL - by williec - 08-26-2011, 05:34 PM
Re: CAN'T FIGURE OUT THE MODEL - by Ron Ramirez - 08-26-2011, 05:34 PM
Re: CAN'T FIGURE OUT THE MODEL - by williec - 08-30-2011, 04:40 PM
Re: CAN'T FIGURE OUT THE MODEL - by Arran - 08-30-2011, 11:13 PM
There are currently 10611 online users. [Complete List]
» 3 Member(s) | 10608 Guest(s)
