Voltages-socket pins for Mystery Control
Battery is a snug fit under the three brackets, as far as thickness goes, but the three "ears" over the battery could be "adjusted" up a little to compensate. Average thickness of the brown battery is 1-11/16". 1.25" would be loose and bang around. Hold down clips wouldn't touch it.
[Image: http://www.philcorepairbench.com/images/...lips01.jpg] [Image: http://www.philcorepairbench.com/images/...lips03.jpg]
(C-size and D-size batteries for comparison.)
Seems there's plenty of thickness for C's, even D's, but 4 D cells in there leaves no room for enough 9-volts.
Ultimately, the two inside brackets have an upper limit as there are bends and setback cutouts for the loop coil support formed into them - about 1/16" more thickness allowance. This translates into a useable thickness of a max of 1-5/8". The catalog diemnsion of 1-1/8" seems way too thin??? A typo propagated thru the various catalogs?? I see why you were worried about C-size....hmmm.
The width has no wiggle room - the outside removable clip canot be shifted in its hole or the top wood case will touch. Same with height dimension - battery is about flush inside the case when closed.
[No subject] - by Chuck Schwark - 10-04-2005, 03:12 PM
[No subject] - by Ron Ramirez - 10-04-2005, 06:09 PM
[No subject] - by Chuck Schwark - 10-04-2005, 07:01 PM
[No subject] - by Chuck Schwark - 10-04-2005, 08:08 PM
[No subject] - by batterymaker - 10-04-2005, 10:38 PM
[No subject] - by Chuck Schwark - 10-04-2005, 10:41 PM
[No subject] - by batterymaker - 10-05-2005, 09:39 PM
[No subject] - by Chuck Schwark - 10-05-2005, 10:48 PM
[No subject] - by Chuck Schwark - 10-12-2005, 11:53 PM
[No subject] - by batterymaker - 10-14-2005, 09:57 PM
[No subject] - by Chuck Schwark - 10-15-2005, 12:16 AM
[No subject] - by batterymaker - 10-15-2005, 09:54 AM
[No subject] - by Chuck Schwark - 10-15-2005, 07:05 PM
[No subject] - by batterymaker - 10-15-2005, 10:52 PM
[No subject] - by Chuck Schwark - 10-16-2005, 10:38 AM
[No subject] - by Chuck Schwark - 10-16-2005, 01:43 PM
[No subject] - by batterymaker - 10-16-2005, 10:56 PM
[No subject] - by batterymaker - 10-16-2005, 10:58 PM
[No subject] - by Chuck Schwark - 10-17-2005, 04:19 PM
[No subject] - by batterymaker - 10-19-2005, 09:25 AM
[No subject] - by Chuck Schwark - 10-19-2005, 09:54 AM
[No subject] - by batterymaker - 10-19-2005, 04:04 PM
[No subject] - by batterymaker - 10-20-2005, 06:18 PM
[No subject] - by Chuck Schwark - 10-20-2005, 10:59 PM
[No subject] - by batterymaker - 10-25-2005, 08:03 PM
[No subject] - by Chuck Schwark - 10-25-2005, 09:07 PM
[No subject] - by Ron Ramirez - 10-25-2005, 09:28 PM
[No subject] - by batterymaker - 10-25-2005, 10:07 PM
[No subject] - by Chuck Schwark - 10-26-2005, 09:16 AM
[No subject] - by batterymaker - 10-30-2005, 11:43 AM
[No subject] - by Chuck Schwark - 10-30-2005, 07:36 PM
[No subject] - by Chuck Schwark - 11-06-2005, 10:03 PM
[No subject] - by batterymaker - 11-06-2005, 10:44 PM
[No subject] - by Chuck Schwark - 11-06-2005, 11:00 PM
[No subject] - by batterymaker - 11-07-2005, 09:10 AM
[No subject] - by Chuck Schwark - 11-07-2005, 10:18 AM
[No subject] - by batterymaker - 11-07-2005, 03:58 PM
[No subject] - by Chuck Schwark - 11-07-2005, 05:24 PM
[No subject] - by batterymaker - 11-07-2005, 11:42 PM
[No subject] - by Chuck Schwark - 11-07-2005, 11:59 PM
[No subject] - by batterymaker - 12-01-2005, 09:25 AM
[No subject] - by Chuck Schwark - 12-01-2005, 10:04 AM
[No subject] - by Guest - 12-01-2005, 03:19 PM
[No subject] - by batterymaker - 12-06-2005, 10:43 AM
[No subject] - by batterymaker - 12-09-2005, 09:31 AM
There are currently 9775 online users. [Complete List]
» 1 Member(s) | 9774 Guest(s)
