Finishing a Grunow 1081 cabinet
Thanks Guys,
I'll take the finish off tomorrow.. suggestions on which toner? When I use a walnut it seems to have a red tint to it. I was thinking a light coat of perfect brown.
Glenn
Re: Finishing a Grunow 1081 cabinet - by exray - 10-06-2011, 06:46 PM
Re: Finishing a Grunow 1081 cabinet - by Glenn Roberts - 10-06-2011, 07:53 PM
Re: Finishing a Grunow 1081 cabinet - by Arran - 10-07-2011, 01:17 AM
Eico 232 VTVM Schematic
There are currently 6495 online users. [Complete List]
» 1 Member(s) | 6494 Guest(s)
