Model 20 Consolette Resto
#43
Yeah, the original is pretty much a "basket" case.. Icon_lol I will definitely repair it though. I built a small 2-way speaker to use for now. I'm going to remove the output transformer and use a 10 watt resistor for the field coil so I dont have the stock speaker hanging off the back of the cabinet. It really does sound good though. Not exactly Hi Fi but definitely nice for an 80 year old radio. Anybody going to Kutztown in a few weeks?
Model 20 Consolette Resto - by badwaxcaps - 07-27-2011, 08:25 PM
Re: Model 20 Consolette Resto - by 7estatdef - 07-27-2011, 10:13 PM
Re: Model 20 Consolette Resto - by Jayce - 07-27-2011, 10:42 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 07-28-2011, 12:11 AM
Re: Model 20 Consolette Resto - by 7estatdef - 07-28-2011, 05:49 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-05-2011, 11:00 AM
Re: Model 20 Consolette Resto - by TA Forbes - 08-05-2011, 12:30 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-05-2011, 07:49 PM
Re: Model 20 Consolette Resto - by TA Forbes - 08-05-2011, 09:57 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-05-2011, 10:51 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-06-2011, 12:50 AM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-06-2011, 01:03 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-06-2011, 07:08 AM
Re: Model 20 Consolette Resto - by Dan - 08-07-2011, 08:24 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-07-2011, 08:43 AM
Re: Model 20 Consolette Resto - by Ron Ramirez - 08-07-2011, 08:46 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-07-2011, 09:19 AM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-12-2011, 11:25 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-13-2011, 09:12 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-22-2011, 12:03 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-22-2011, 08:49 AM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-24-2011, 12:31 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-24-2011, 04:35 PM
Re: Model 20 Consolette Resto - by Chicago Jimmy - 08-24-2011, 06:06 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-24-2011, 07:09 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-24-2011, 09:36 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-24-2011, 11:53 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-25-2011, 11:19 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 12:39 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-26-2011, 04:11 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 06:44 PM
Re: Model 20 Consolette Resto - by Ron Ramirez - 08-26-2011, 07:08 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 07:16 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 07:18 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-26-2011, 07:26 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 11:11 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-26-2011, 11:13 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-27-2011, 12:37 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-28-2011, 09:56 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-29-2011, 01:33 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-30-2011, 07:54 AM
Re: Model 20 Consolette Resto - by 7estatdef - 08-30-2011, 05:08 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-30-2011, 07:57 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-31-2011, 02:30 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-31-2011, 05:19 PM
Re: Model 20 Consolette Resto - by 7estatdef - 08-31-2011, 07:48 PM
Re: Model 20 Consolette Resto - by badwaxcaps - 08-31-2011, 09:19 PM
There are currently 10524 online users. [Complete List]
» 2 Member(s) | 10522 Guest(s)
