Model 87 Audio input xformer and output xformer to 45 tubes
Hi Jim,
If it is the trans #25 connecting between the first AF 226 and the second AF 245's you can use the Hammond HX124A from Radio Daze. I used it on mine and it works great. Hope this helps,
Richard
[No subject] - by rjm - 07-25-2006, 04:32 PM
[No subject] - by Jimony - 07-26-2006, 10:27 AM
[No subject] - by rjm - 07-26-2006, 02:48 PM
There are currently 9705 online users. [Complete List]
» 1 Member(s) | 9704 Guest(s)
