Please ID this chassis..I need a cabinet
Ron did identify this chassis for me but I lost the information,,so if anyone knows what model it is and what cabinet I will need, let me know...... thanks Dan
[Image: http://i318.photobucket.com/albums/mm405...4Small.jpg]
[Image: http://i318.photobucket.com/albums/mm405...5Small.jpg]
[Image: http://i318.photobucket.com/albums/mm405...3Small.jpg]
[Image: http://i318.photobucket.com/albums/mm405...2Small.jpg]
   Living in Calgary Alberta
Please ID this chassis..I need a cabinet - by Dan Walker - 09-01-2011, 12:06 AM
There are currently 7371 online users. [Complete List]
» 4 Member(s) | 7367 Guest(s)
AvatarAvatarAvatarAvatar
