Philco 643 restoration
I'm slowly making progress on the chassis. I discovered that the audio coupling transformer is also a replacement but tests OK. The same cannot be said of the antenna coil though Icon_sad
[Image: http://farm7.static.flickr.com/6183/6106...ecdd_z.jpg]
What I find really strange is that every tap of this coil is open. Someone had connected a low ohm flexible resistor from one tap to ground. I assume that was an attempt to restore reception.
Surprisingly, the antenna coil in the modified chassis is good. So I have the option of repairing this one or swapping it out. Either way, it's not going to be fun. So many connections to deal with ...
Philco 643 restoration - by Bob Andersen - 08-04-2011, 10:13 PM
Re: Philco 643 restoration - by Bob Andersen - 08-05-2011, 01:44 AM
Re: Philco 643 restoration - by Ron Ramirez - 08-05-2011, 06:38 AM
Re: Philco 643 restoration - by TA Forbes - 08-05-2011, 12:36 PM
Re: Philco 643 restoration - by Ron Ramirez - 08-05-2011, 12:59 PM
Re: Philco 643 restoration - by Bob Andersen - 08-05-2011, 07:28 PM
Re: Philco 643 restoration - by TA Forbes - 08-05-2011, 10:07 PM
Re: Philco 643 restoration - by Bob Andersen - 09-02-2011, 04:29 PM
Re: Philco 643 restoration - by TA Forbes - 09-02-2011, 11:39 PM
Re: Philco 643 restoration - by Ron Ramirez - 09-02-2011, 11:43 PM
Re: Philco 643 restoration - by Bob Andersen - 09-03-2011, 12:30 AM
Re: Philco 643 restoration - by Ron Ramirez - 09-03-2011, 07:59 AM
Re: Philco 643 restoration - by 7estatdef - 09-03-2011, 11:44 AM
Re: Philco 643 restoration - by Arran - 09-05-2011, 01:24 AM
Re: Philco 643 restoration - by Bob Andersen - 09-07-2011, 11:11 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6849 online users. [Complete List]
» 1 Member(s) | 6848 Guest(s)
