48-1262 record changer problem
It would appear that the single 78 record I had was not able to trip the auto return mechanism. The four more records that I have since acquired all trip correctly. Rotten luck, I guess in picking a bad record to test with. Though, all things considered, lucky in that the changer still works after probably sitting idle for more than 20 years!
48-1262 record changer problem - by ETS1979 - 07-21-2011, 08:04 PM
Re: 48-1262 record changer problem - by ETS1979 - 07-26-2011, 07:17 PM
Re: 48-1262 record changer problem - by ETS1979 - 07-27-2011, 09:03 AM
Re: 48-1262 record changer problem - by ETS1979 - 07-27-2011, 06:45 PM
Re: 48-1262 record changer problem - by ETS1979 - 07-30-2011, 12:16 PM
Re: 48-1262 record changer problem - by ETS1979 - 07-30-2011, 12:18 PM
Re: 48-1262 record changer problem - by codefox1 - 07-30-2011, 12:40 PM
Re: 48-1262 record changer problem - by ETS1979 - 07-30-2011, 03:52 PM
Re: 48-1262 record changer problem - by codefox1 - 07-30-2011, 05:33 PM
Re: 48-1262 record changer problem - by ETS1979 - 08-23-2011, 10:08 PM
Re: 48-1262 record changer problem - by ETS1979 - 09-02-2011, 07:07 PM
Re: 48-1262 record changer problem - by ETS1979 - 09-09-2011, 08:49 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5451 online users. [Complete List]
» 1 Member(s) | 5450 Guest(s)
