37-60B?
Hi
The 37-60 is not the most desirable Philco out there, but it certainly isn't the worst. With five tubes, it is a good performer.
The important thing here, is whether or not the photofinished front panel is still in good condition, or not. Here is a late version 37-60B with excellent photofinish:
http://www.philcoradio.com/gallery/1937b.htm#j
If the one you are looking at has good photofinish, you should grab it if the price isn't ridiculously high. How much $$ is the seller asking for it?
37-60B? - by Dave - 09-04-2011, 09:44 PM
Re: 37-60B? - by Ron Ramirez - 09-04-2011, 10:23 PM
Re: 37-60B? - by Dave - 09-04-2011, 11:02 PM
Re: 37-60B? - by Ron Ramirez - 09-05-2011, 06:24 AM
Re: 37-60B? - by Dave - 09-05-2011, 02:11 PM
Re: 37-60B? - by Ron Ramirez - 09-05-2011, 02:21 PM
There are currently 10469 online users. [Complete List]
» 2 Member(s) | 10467 Guest(s)
